Honda
تصویر بحث و تبادل نظر در باره موتور سیکلتهای touring - cruisers
metexs
پست: 634
تاریخ عضویت: 07 نوامبر 2009, 13:40
نوع خودرو: Golf MKII
محل اقامت: Esfahan
Honda
پست توسط metexs » 07 ژانویه 2011, 14:10
2010 Honda Gold Wing:
مشخصات:
1832 سی سی، 6 سیلندر
ENGINE
Engine Type 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke 74.0mm x 71.0mm
Induction Programmed Fuel Injection (PGM-FI)
Ignition Computer-controlled digital with three-dimensional mapping
Compression Ratio 9.8:1
Valve Train SOHC; two valves per cylinder
DRIVE TRAIN
Transmission Five-speed including Overdrive, plus electric reverse
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 45mm cartridge fork with anti-dive system, 5.5 inches of travel
Rear Suspension Pro-Arm single-side swingarm with Pro-Link single shock with computer-controlled spring-preload adjustment with two memory presets; 4.1 inches of travel
Front Brake Dual full-floating 296mm discs with CBS three-piston calipers
Rear Brake Single ventilated 316mm disc with CBS three-piston caliper
Front Tire 130/70R-18
Rear Tire 180/60R-16
DIMENSIONS
Rake 29.15 degrees
Trail 109.0mm (4.3 inches)
Wheelbase 66.5 inches
Seat Height 29.1 inches
Curb Weight 895 – 928 pounds, depending on option packages selected (Includes all standard equipment, required fluids and full tank of fuel—ready to ride.)
Fuel Capacity 6.6 gallons
Miles Per Gallon 36 MPG*
OTHER
Model ID GL18HPM
Emissions Meets current CARB and EPA standards.
Available Colors Metallic Red, Metallic Black, Pearl Yellow, Metallic Titanium
FACTORY WARRANTY IN FORMATION
Three Years Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
عليرضا مقدم
پست: 612
تاریخ عضویت: 11 سپتامبر 2010, 06:39
Re: Honda
پست توسط عليرضا مقدم » 04 فوریه 2011, 17:59
metexs نوشته شده:2010 Honda Gold Wing:
اين رنگش قشنگه !
ولي در كل ازش خوشم نيومد ! (نظر شخصي)
reza_243
پست: 866
تاریخ عضویت: 30 مارس 2009, 15:40
نوع خودرو: پژو206-TU3,تکتاز 125
Re: Honda
پست توسط reza_243 » 05 فوریه 2011, 11:32
یه مدل 1500 سی سی این رو که فکر کنم مدل 2005 باشه حدوداً تو ستارخان برای فروش گذاشتند 45 تومن
رنگ بنفش و ظاهراً سالم
pasargad-auto
پست: 255
تاریخ عضویت: 02 فوریه 2011, 14:17
نوع خودرو: RADISSON125CC
Re: Honda
پست توسط pasargad-auto » 04 نوامبر 2011, 11:20
راز هایی در مورد این موتور استسنایی !
وزن 500 کیلو شتاب 0 تا 100 4 ثانیه !
باک 20 لیتر
وجود کروز کنترل !
دو چرخ دیسکی !
وجود سیستم صوتی خوب !
خیلی عالیه !
ما ایرانیا از همه چی محرومیم حتی از این موتور ها
متاسفم ! اگه بود میخریدم !
اسمم علیرضا هست.
به دلیل مشکلات و کار ها خیلی کمتر میام.
kevin
پست: 51
تاریخ عضویت: 12 دسامبر 2009, 00:22
نوع خودرو: bajaj avenger 200cc
Re: Honda
پست توسط kevin » 04 نوامبر 2011, 11:43
یه نکته هم این حقیر راجع به این موتور میدونم که جالبه:
این موتور گرمکن صندلی برای 2 سرنشین داره + بخاری که رو دستا و ساق و زانو ی پا باد گرم میزنه.
جی پی اس هم داره که از روی خود ال سی دی (فینگر تاچ ) میشه باهاش کار کرد.
نکته ی جالب آخری هم اینکه این موتور ایریگ هم داره
old wolf
پست: 1647
تاریخ عضویت: 10 اکتبر 2009, 23:40
نوع خودرو: Proton wira -Hyosung
محل اقامت: ....
Re: Honda
پست توسط old wolf » 05 نوامبر 2011, 20:26
اگه با این موتور زمین بخوری باید یه ملتی بسیج بشن از زمین بلندش کنن :hah:
ماشالا 500 کیلو
من موتور 150 کیلویی خودم رو به زور عقب جلو میکنم
TUNING TALK
عليرضا مقدم
پست: 612
Re: Honda
پست توسط عليرضا مقدم » 06 نوامبر 2011, 01:08
معلومه چطور ميره رو جك وسط ؟؟! برقي بايد باشه !
amir74
پست: 17
تاریخ عضویت: 29 آپریل 2011, 13:18
نوع خودرو: shoka 250
Re: Honda
پست توسط amir74 » 02 می 2013, 10:47
دوستان هندا گلدوئینگ 1000 از این قدیمیا واسه زمان شاه هست تهران چند بر می دارن چون موتور کلکسیونی هست و قیمت بالایی داره.
kaveh73
پست: 509
تاریخ عضویت: 15 اکتبر 2011, 19:28
نوع خودرو: ......!
Re: Honda
پست توسط kaveh73 » 02 می 2013, 11:17
ماشالا 500 کیلو
دنده عقب داره این موتور
سلامتیه همه اونایی که تو خیالمونن ولی بیخیالمونن
painkiller
پست: 108
تاریخ عضویت: 18 دسامبر 2012, 01:00
نوع خودرو: daelim VJf250
محل اقامت: tehran
Re: Honda
پست توسط painkiller » 11 آگوست 2013, 21:30
فكر كنم يه سرويس تعويض روغن و فيلتر روغن و هوا و آچاركشيش و رسيدگيش بالاي 500 باشه !! هر چي امكانات بالا ميره هزينه هم بالاتره.....
مرگ زيباس آن هنگامي كه زندگي در عذاب به پايانش نزديك مي شود....
بازگشت به “تورینگ و کروزر”
